The following example shows output from the repquota command on a system that has quotas enabled on only one file system (/export/home).
# repquota -va
/dev/dsk/c0t3d0s7 (/export/home):
Block limits File limits
User used soft hard timeleft used soft hard timeleft
#301 -- 0 1 2.0 days 0 2 3
#341 -- 57 50 60 7.0 days 2 90 100
Block limits |
used |
Is the current block usage. |
soft |
Is the soft block limit. |
hard |
Is the hard block limit. |
timeleft |
Is the amount of time, in days, left on the quota timer. |
File limits |
used |
Is the current inode usage. |
soft |
Is the soft inode limit. |
hard |
Is the hard inode limit. |
timeleft |
