The following example shows the contents of the temporary file opened by the edquota command on a system where /export/home is the only mounted file system with quotas. The default value, 0, means that the default time limit of one week is used.
fs /export/home blocks time limit = 0 (default), files time limit = 0 (default) |
The following example shows the same temporary file after the time limit for exceeding the blocks quota has been changed to two weeks, and the time limit for exceeding the number of files has been changed to 16 days.
fs /export/home blocks time limit = 2 weeks, files time limit = 16 days |
