System Administration Guide: Advanced Administration
The dumpadm Command
Use the dumpadm command to manage system crash dump information in the Solaris environment.
The following table describes dumpadm's configuration parameters.
Dump Parameter
Description
dump device
The device that stores dump data temporarily as the system crashes. When the dump device is not the swap area, savecore runs in the background, which speeds up the boot process.
savecore directory
The directory that stores system crash dump files.
dump content
Type of memory data to dump.
minimum free space
Minimum amount of free space required in the savecore directory after saving crash dump files. If no minimum free space has been configured, the default is one Mbyte.
For more information, see dumpadm(1M).
The dump configuration parameters managed by the dumpadm command are stored in the /etc/dumpadm.conf file.
Note –
Do not edit the /etc/dumpadm.conf file manually. Editing this file manually could result in an inconsistent system dump configuration.
How the dumpadm Command Works
During system startup, the dumpadm command is invoked by the /etc/init.d/savecore script to configure crash dumps parameters based on information in the /etc/dumpadm.conf file.
Specifically, dumpadm initializes the dump device and the dump content through the /dev/dump interface.
After the dump configuration is complete, the savecore script looks for the location of the crash dump file directory by parsing the content of /etc/dumpadm.conf file. Then, savecore is invoked to check for crash dumps and check the content of the minfree file in the crash dump directory.
