System Administration Guide: Advanced Administration
Example—Diagnosing and Correcting Search Path Problems
This example shows that the mytool executable is not in any of the directories in the search path using the which command.
venus% mytool
mytool: Command not found
venus% which mytool
no mytool in /sbin /usr/sbin /usr/bin /etc /home/ignatz/bin  .
venus% echo $PATH
venus% vi ~.cshrc
(Add appropriate command directory to the search path)
venus% source .cshrc
venus% mytool
If you cannot find a command, look at the man page for its directory path. For example, if you cannot find the lpsched command (the lp printer daemon), lpsched(1M) tells you the path is /usr/lib/lp/lpsched.
