The Solaris_UserAcl class inherits the string property capability with a default value r (read only) from theSolaris_Acl class.
You can set the capability property to any one of these values for access privileges.
Access Right |
Description |
r |
Read |
rw |
Read and Write |
w |
Write |
none |
No access |
The Solaris_UserAcl class defines the following two key properties. Only one instance of the namespace and user-name ACL pair can exist in a namespace.
Property |
Data Type |
Purpose |
nspace |
string |
Identifies the namespace to which this ACL applies |
username |
string |
Identifies the user to which this ACL applies |
Create an instance of the Solaris_UserAcl class.
For example:
/* Create a namespace object initialized with root\security
(name of namespace) on the local host. */
CIMNameSpace cns = new CIMNameSpace("", "root\security");
// Connect to the root\security namespace as root.
cc = new CIMClient(cns, user, user_passwd);
// Get the Solaris_UserAcl class
cimclass = cc.getClass(new CIMObjectPath("Solaris_UserAcl");
// Create a new instance of the Solaris_UserAcl
class ci = cimclass.newInstance();
Set the capability property to the desired access rights.
/* Change the access rights (capability) to read/write for user Guest
on objects in the root\molly namespace.*/
ci.setProperty("capability", new CIMValue(new String("rw"));
ci.setProperty("nspace", new CIMValue(new String("root\molly"));
ci.setProperty("username", new CIMValue(new String("guest"));
Update the instance.
... // Pass the updated instance to the CIM Object Manager cc.createInstance(new CIMObjectPath(), ci); ...
