Solaris WBEM Developer's Guide
Retrieving Class Definitions
The getClass method gets a CIM class. When a class is created, the class inherits the methods and properties of all parent classes in the class hierarchy. The getClass method takes the localOnly Boolean argument.
Example 4–16 Retrieving a Class Definition
This example uses the following methods to retrieve a class definition:
import java.rmi.*;
import javax.wbem.client.CIMClient;
import javax.wbem.cim.CIMInstance;
import javax.wbem.cim.CIMValue;
import javax.wbem.cim.CIMProperty;
import javax.wbem.cim.CIMNameSpace;
import javax.wbem.cim.CIMObjectPath;
import javax.wbem.cim.CIMClass;
import javax.wbem.cim.CIMException;
import java.util.Enumeration;
 * Gets the class specified in the command line. Works in the default
 * namespace root\cimv2.
public class GetClass {
    public static void main(String args[]) throws CIMException {
        CIMClient cc = null;
        try {
           CIMNameSpace cns = new CIMNameSpace(args[0]);
           UserPrincipal up = new UserPrincipal("root");
           PasswordCredential pc = new PasswordCredential("root_password");
           cc = new CIMClient(cns);
           CIMObjectPath cop = new CIMObjectPath(args[1]);
           // Returns only the methods and properties that
           // are local to the specified class (localOnly is true).
           cc.getClass(cop, true);
        } catch (Exception e) {
            System.out.println("Exception: "+e);
        if(cc != null) {
            cc.close();
