Solaris WBEM Developer's Guide
Deleting an Instance
Use the deleteInstance method to delete an instance.
Example 4–6 Deleting Instances
The example does the following:
import java.rmi.*;
import java.util.Enumeration;
import javax.wbem.cim.CIMClass;
import javax.wbem.cim.CIMException;
import javax.wbem.cim.CIMInstance;
import javax.wbem.cim.CIMNameSpace;
import javax.wbem.cim.CIMObjectPath;
import javax.wbem.client.CIMClient;
import javax.wbem.client.PasswordCredential;
import javax.wbem.client.UserPrincipal;
 * Returns all instances of the specified class.
 * This example takes five arguments: hostname (args[0]), username
 * (args[1]), password (args[2]) namespace (args[3] and classname (args[4])
 * It will delete all instances of the specified classname.  The specified
 * username must have write permissions to the specified namespace
public class DeleteInstances {
    public static void main(String args[]) throws CIMException {
        CIMClient cc = null;
        // if not five arguments, show usage and exit
        if (args.length != 5) {
           System.out.println("Usage: DeleteInstances host username " +
                              "password namespace classname ");
           System.exit(1);
        try {
            // args[0] contains the hostname and args[3] contains the
            // namespace.  We create a CIMNameSpace (cns) pointing to
            // the specified namespace on the specified host
            CIMNameSpace cns = new CIMNameSpace(args[0], args[3]);
            // args[1] and args[2] contain the username and password.
            // We create a UserPrincipal (up) using the username and
            // a PasswordCredential using the password.
            UserPrincipal up = new UserPrincipal(args[1]);
            PasswordCredential pc = new PasswordCredential(args[2]);
            // Connect to the CIM Object Manager and pass it the
            // CIMNameSpace, UserPrincipal and PasswordCredential objects
            // we created.
            cc = new CIMClient(cns, up, pc);
            // Get the class name (args[4]) and create a CIMObjectPath
            CIMObjectPath cop = new CIMObjectPath(args[4]);
            // Get an enumeration of all the instance object paths of the
            // class and all subclasses of the class.  An instance object
            // path is a reference used by the CIM object manager to
            // locate the instance
            Enumeration e = cc.enumerateInstanceNames(cop);
            // Iterate through the instance object paths in the enumeration.
            // Construct an object to store the object path of each
            // enumerated instance, print the instance and then delete it
            while (e.hasMoreElements()) {
                CIMObjectPath  op = (CIMObjectPath)e.nextElement();
                System.out.println(op);
                cc.deleteInstance(op);
            } // end while
        } catch (Exception e) {
        // if we have an exception, catch it and print it out.
        System.out.println("Exception: "+e);
        } // end catch
        // close session.
        if (cc != null) {
            cc.close();
