Solaris WBEM Developer's Guide
Solaris_UserAcl Class
The Solaris_UserAcl class inherits the string property capability with a default value r (read only) from theSolaris_Acl class.
You can set the capability property to any one of these values for access privileges.
Access Right
Description
r
Read
rw
Read and Write
w
Write
none
No access
The Solaris_UserAcl class defines the following two key properties. Only one instance of the namespace and user-name ACL pair can exist in a namespace.
Property
Data Type
Purpose
nspace
string
Identifies the namespace to which this ACL applies
username
string
Identifies the user to which this ACL applies
How to Set Access Control for a User
  1. Create an instance of the Solaris_UserAcl class.
    For example:
    /* Create a namespace object initialized with root\security
    (name of namespace) on the local host. */
    CIMNameSpace cns = new CIMNameSpace("", "root\security");
    // Connect to the root\security namespace as root.
    cc = new CIMClient(cns, user, user_passwd);
    // Get the Solaris_UserAcl class
    cimclass = cc.getClass(new CIMObjectPath("Solaris_UserAcl");
    // Create a new instance of the Solaris_UserAcl
    class ci = cimclass.newInstance();
  2. Set the capability property to the desired access rights.
    For example:
    /* Change the access rights (capability) to read/write for user Guest
    on objects in the root\molly namespace.*/
    ci.setProperty("capability", new CIMValue(new String("rw"));
    ci.setProperty("nspace", new CIMValue(new String("root\molly"));
    ci.setProperty("username", new CIMValue(new String("guest"));
  3. Update the instance.
    For example:
    // Pass the updated instance to the CIM Object Manager
    cc.createInstance(new CIMObjectPath(), ci);
