Solaris WBEM Developer's Guide
Writing a Method Provider
The method invokeMethod is the only way that a client program can call the methods of Solaris WBEM providers. This condition is true for both providers that are built in or that are added by developers.
The following sample code creates the Solaris_ComputerSystem provider class that routes requests from the CIMOM to one or more specialized providers. These providers handle requests for dynamic data for a particular type of managed object. For example, the Solaris_Package provider handles requests to execute methods in the Solaris_Package class.
The method provider implements a single method, invokeMethod. This method calls the appropriate provider to either reboot a system, shut down a system, or delete a serial port.
Example 6–2 Method Provider
public class Solaris_ComputerSystem implements MethodProvider {
	ProviderCIMOMHandle pch = null;
	public void initialize(CIMOMHandle ch) throws CIMException {
		pch = (ProviderCIMOMHandle)ch;
	public void cleanup() throws CIMException {
	public CIMValue invokeMethod(CIMObjectPath op, String methodName,
			Vector inParams, Vector outParams)  throws CIMException {
		if (op.getObjectName().equalsIgnoreCase("solaris_computersystem")) {
			if (methodName.equalsIgnoreCase("reboot")) {
				// call helper function, not shown here
				return new CIMValue(rebootSystem());
			if (methodName.equalsIgnoreCase("shutdown")) {
				return new CIMValue(shutdownSystem());
		if (op.getObjectName().equalsIgnoreCase("solaris_serialport")) {
			if (methodName.equalsIgnoreCase("disableportservice")) {
				return new CIMValue(deletePort(op));
		// error if we get here
		throw new CIMException(CIMException.CIM_ERR_NOT_SUPPORTED,
			"The requested function does not exist");
	// helper functions would be defined below
