System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
client_info Attributes and Object Class
Create attributes and object class as below, and then create the container for the client_info data. The suggested container name is ou=ClientInfo. LDIF data is for ldapadd(1). The attribute and object class OIDs used in the following are examples only.
dn: cn=schema
changetype: modify
add: attributetypes
attributetypes:	( 1.3.6.1.4.1.42.2.27.5.42.42.12.0 \
		  NAME 'nisplusClientInfoAttr' \
		  DESC 'NIS+ client_info table client column' \
		  SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE )
attributetypes:	( 1.3.6.1.4.1.42.2.27.5.42.42.12.1 \
		  NAME 'nisplusClientInfoInfo' \
		  DESC 'NIS+ client_info table info column' \
		  SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE )
attributetypes:	( 1.3.6.1.4.1.42.2.27.5.42.42.12.2 \
		  NAME 'nisplusClientInfoFlags' \
		  DESC 'NIS+ client_info table flags column' \
dn: cn=schema
changetype: modify
add: objectclasses
objectclasses:	( 1.3.6.1.4.1.42.2.27.5.42.42.13.0 \
		  NAME 'nisplusClientInfoData' \
		  DESC 'NIS+ client_info table data' \
		  SUP top STRUCTURAL MUST ( cn ) \
		  MAY ( nisplusClientInfoAttr $ nisplusClientInfoInfo $ nisplusClientInfoFlags ) )
To create the container, put the following LDIF data in a file. Substitute your actual search base for searchBase. )
dn: ou=ClientInfo, searchBase
objectClass: organizationalUnit
ou: ClientInfo
objectClass: top
Use the above file as input to the ldapadd command in order to create the ou=ClientInfo container. For example, if your LDAP administrator DN is cn=directory manager, and the file with the LDIF data is called cifile, do the following.
# ldapadd -D cn="directory manager" -f cifile
Depending on the authentication required, the ldapadd command might prompt for a password.
The /var/nis/NIS+LDAPmapping.template file contains commented-out definitions for the client_info.org_dir table. Copy these to the actual mapping file, enable by removing the comment character '#', and restart the rpc.nisd daemon. If necessary, synchronize NIS+ and LDAP data as described in NIS+ to LDAP Migration Scenarios.
