The nisdefaults command displays the seven default values currently active in the namespace. These default values are either
Preset values supplied by the NIS+ software
The defaults specified in the NIS_DEFAULTS environment variable (if you have NIS_DEFAULTS values set)
Any object that you create on this machine will automatically acquire these default values unless you override them with the -D option of the command you are using to create the object.
Table 15–12 The Seven NIS+ Default Values and nisdefaults Options|
Default |
Option |
From |
Description |
Domain |
-d |
/etc/defaultdomain |
Displays the home domain of the machine from which the command was entered. |
Group |
-g |
Displays the group that would be assigned to the next object created from this shell. |
Host |
-h |
uname -n |
Displays the machine's host name. |
Principal |
-p |
gethostbyname() |
Displays the fully qualified user name or host name of the NIS+ principal who entered the nisdefaults command. |
Access Rights |
-r |
Displays the access rights that will be assigned to the next object or entry created from this shell. Format: ----rmcdr---r--- |
Search path |
-s |
Displays the
syntax of the search path, which indicate the domains that NIS+ will search
through when looking for information. Displays the value of the |
Time-to-live |
-t |
Displays the time-to-live that will be assigned to the next object created from this shell. The default is 12 hours. |
All (terse) |
-a |
Displays all seven defaults in terse format. |
Verbose |
-v |
Display specified values in verbose mode. |
You can use these options to display all default values or any subset of them:
master% nisdefaults Principal Name : topadmin.doc.com. Domain Name : doc.com. Host Name : rootmaster.doc.com. Group Name : salesboss Access Rights : ----rmcdr---r--- Time to live : 12:00:00:00:00 Search Path : doc.com. |
To display all values in terse format, add the -a option.
To display a subset of the values, use the appropriate options. The values are displayed in terse mode. For example, to display the rights and search path defaults in terse mode, type:
rootmaster% nisdefaults -rs ----rmcdr---r--- doc.com. |
To display a subset of the values in verbose mode, add the -v flag.
