This chapter describes NIS+ groups and how to administer them.
Some NIS+ security group tasks can be performed more easily with Solstice AdminSuite tools if you have them available.
NIS+ might not be supported in a future release. Tools to aid the migration from NIS+ to LDAP are available in the Solaris 9 operating environment (see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)). For more information, visit http://www.sun.com/directory/nisplus/transition.html.
In a Solaris-NIS+ environment, there are three kinds of groups: UNIX groups, net groups, and NIS+ groups.
UNIX groups. A UNIX group is simply a collection of users who are given additional UNIX access permissions. In an NIS+ namespace, UNIX group information is stored in the group table located in the org_dir directory object (group.org_dir). See Chapter 19, Administering NIS+ Tables, for information on how to add, modify, or delete members of a UNIX group.
Net groups. A net group is a group of machines and users that have permission to perform remote operations on other machines. In an NIS+ namespace, net groups information is stored in the netgroup table located in the org_dir directory object (netgroup.org_dir). See Chapter 19, Administering NIS+ Tables, for information on how to add, modify, or delete members of a net groups.
NIS+ groups. An NIS+ group is a set of NIS+ users that are assigned specific access rights to NIS+ objects, usually for the purpose of administering the namespace. NIS+ group information is stored in tables located in the groups_dir directory object.
NIS+ groups are used to assign access rights to NIS+ objects to one or more NIS+ principles. These access rights are described in Chapter 11, NIS+ Security Overview. Information about NIS+ groups is stored in tables located in the NIS+ groups_dir directory object. Information about each group is stored in a table of the same name. For example, information about the admin group is stored in admin.groups_dir.
It is recommended practice to create at least one NIS+ group called admin. The admin NIS+ group is normally used to designate those users who are to have NIS+ access rights. You can name this group anything you want, but the NIS+ manual set assumes that the group with NIS+ administrator privileges is named admin. You can also create multiple NIS+ groups with different sets of users and different sets of rights.
Always use the nisgrpadm command to work with NIS+ group membership. You can also use the nisls and nischgrp commands on the group table. Do not use the nistbladm command on the group table.
For a complete description of NIS+ group-related commands and their syntax and options, see the NIS+ man pages.
The nisgrpadm command performs most group administration tasks but several other commands affect groups as well:
Table 17–1 Commands That Affect Groups
Command |
Description |
See |
nissetup |
Creates, among other things, the directory in which a domain's groups are stored: groups_dir. |
nisls |
Lists the contents of the groups_dir directory; in other words, all the groups in a domain. For each named groups there will be a table of that name in groups_dir. | |
nischgrp |
Changes or assigns a group to any NIS+ object. | |
niscat |
Lists the object properties and membership of an NIS+ group. | |
nisdefaults |
Lists, among other things, the group that will be assigned to any new NIS+ object. |
For a complete description of these commands and their syntax, and options, see the NIS+ man pages.
Do not use the nistbladm command to work with the NIS+ groups table.
NIS+ groups can have three types of members: explicit, implicit, and recursive; and three types of nonmembers, also explicit, implicit, and recursive. These member types are used when adding or removing members of a group as described in The nisgrpadm Command.
Explicit. An individual principal. Identified by principal name. The name does not have to be fully qualified if entered from its default domain.
Implicit. All the NIS+ principals who belong to an NIS+ domain. They are identified by their domain name, preceded by the * symbol and a dot. The operation you select applies to all the members in the group.
Recursive. All the NIS+ principals that are members of another NIS+ group. They are identified by their NIS+ group name, preceded by the @ symbol. The operation you select applies to all the members in the group.
NIS+ groups also accept nonmembers in all three categories: explicit, implicit, and recursive. Nonmembers are principals specifically excluded from a group that they otherwise would be part of.
Nonmembers are identified by a minus sign in front of their name:
Explicit-nonmember. Identified by a minus sign in front of the principal name.
Implicit-nonmember. Identified by a minus sign, * symbol, and dot in front of the domain name.
Recursive nonmember. Identified by a minus sign and @ symbol in front of the group name.
The order in which inclusions and exclusions are entered does not matter. Exclusions always take precedence over inclusions. Thus, if a principal is a member of an included implicit domain and also a member of an excluded recursive group, then that principal is not included.
Thus, when using the nisgrpadm command, you can specify group members and nonmembers as shown in Table 17–2:
Table 17–2 Specifying Group Members and Nonmembers
Type of member |
Syntax |
Explicit member |
username.domain |
Implicit member |
*.domain |
Recursive member |
@groupname.domain |
Explicit nonmember |
-username.domain |
Implicit nonmember |
-*.domain |
Recursive nonmember |
@groupname.domain |
The niscat -ocommand can be used to list the object properties and membership of an NIS+ group.
To list the object properties of a group, you must have read access to the groups_dir directory in which the group is stored. Use niscat -o and the group's fully qualified name, which must include its groups_dir subdirectory:
niscat -o group-name.groups_dir.domain-name |
For example:
rootmaster# niscat -o sales.groups_dir.doc.com. Object Name : sales Owner : rootmaster.doc.com. Group : sales.doc.com. Domain : groups_dir.doc.com. Access Rights : ----rmcdr---r--- Time to Live : 1:0:0 Object Type : GROUP Group Flags : Group Members : rootmaster.doc.com. topadmin.doc.com. @.admin.doc.com. *.sales.doc.com. |
A better list of members is provided by the nisgrpadm -l command.
Several of the group's properties are inherited from the NIS_DEFAULTS
environment variable, unless
they were overridden when the group was created. The group flags field is
currently unused. In the list of group members, the * symbol identifies member
domains and the @ symbol identifies member groups.
The nisgrpadm command creates, deletes, and performs miscellaneous administration operations on NIS+ groups. To use nisgrpadm, you must have access rights appropriate for the operation.
Table 17–3 Rights Required for nisgrpadm Command
This Operation |
Requires This Access Right |
To This Object |
Create a group |
Create |
groups_dir directory |
Destroy a group |
Destroy |
List the Members |
Read |
the group object |
Add Members |
Modify |
the group object |
Remove Members |
Modify |
the group object |
The nisgrpadm has two main forms, one for working with groups and one for working with group members.
To create or delete a group, or to lists its members use these forms:
nisgrpadm -c group-name.domain-name nisgrpadm -d group-name nisgrpadm -l group-name |
To add or remove members, or determine if they belong to the group use this form (where member... can be any combination of the six membership types listed in Table 17–2):
nisgrpadm -a group-name member... nisgrpadm -r group-name member... nisgrpadm -t group-name member... |
All operations except create (-c) accept a partially qualified group-name. However, even for the -c option, nisgrpadm does not require the use of groups_dir in the group-name argument. In fact, it won't accept it.
To create an NIS+ group, you must have create rights to the groups_dir directory of the group's domain. Use the -c option and a fully qualified group name:
nisgrpadm -c group-name. domainname |
When you create a group, an NIS+ groups table with the name you have given is created in groups_dir. You can use nisls to confirm that the new group table now exists in groups_dir, and niscat to list the groups members listed in the table.
A newly created group contains no members. See Adding Members to an NIS+ Group for information on how to specify who belongs to a group.
The example below creates three groups named admin. The first is in the doc.com. domain, the second in sales.doc.com., and the third in manf.doc.com. All three are created on the master server of their respective domains.
rootmaster# nisgrpadm -c admin.doc.com. Group admin.doc.com. created. salesmaster# nisgrpadm -c admin.sales.doc.com. Group admin.sales.doc.com. created. manfmaster# nisgrpadm -c admin.manf.doc.com. Group admin.manf.doc.com. created. |
The group you create will inherit all the object properties specified
in the NIS_DEFAULTS
variable;
that is, its owner, owning group, access rights, time-to-live, and search
path. You can view these defaults by using the nisdefaults
command (described in Chapter 15, Administering NIS+ Access Rights). Used without options,
it provides this output:
rootmaster# nisdefaults Principal Name : rootmaster.doc.com. Domain Name : doc.com. Host Name : rootmaster.doc.com. Group Name : Access Rights : ----rmcdr---r--- Time to live : 12:0:0 Search Path : doc.com. |
The owner is listed in the Principal Name: field. The owning group is
listed only if you have set the NIS_GROUP
environment variable. For example, assuming a C-shell, to set NIS_GROUP
to fns_admins.doc.com:
rootmaster# setenv NIS_GROUP fns_admins.doc.com |
You can override any of these defaults at the time you create the group by using the -D option:
salesmaster# nisgrpadm -D group=special.sales.doc.com.-c admin.sales.doc.com. Group admin.sales.doc.com. created. |
To delete an NIS+ group, you must have destroy rights to the groups_dir directory in the group's domain. Use the -d option:
nisgrpadm -d group-name |
If the default domain is set properly, you don't have to fully-qualify the group name. However, you should check first (use nisdefaults), because you could unintentionally delete a group in another domain. The example below deletes the test.sales.doc.com. group.
salesmaster% nisgrpadm -d test.sales.doc.com. Group `test.sales.doc.com.' destroyed. |
To add members to an NIS+ group you must have modify rights to the group object. Use the -a option:
nisgrpadm -a group-name members. . . |
As described in NIS+ Group Member Types, you can add principals (explicit members), domains (implicit members), and groups (recursive members). You don't have to fully qualify the name of the group or the name of the members who belong to the default domain. This example adds the NIS+ principals panza and valjean, both from the default domain, sales.doc.com., and the principal makeba, from the manf.doc.com. domain, to the group top-team.sales.doc.com.
client% nisgrpadm -a Ateam panza valjean makeba.manf.doc.com. Added panza.sales.doc.com to group Ateam.sales.doc.com Added valjean.sales.doc.com to group Ateam.sales.doc.com Added makeba.manf.doc.com to group Ateam.sales.doc.com |
To verify the operation, use the nisgrpadm -l option. Look for the members under the Explicit members heading.
This example adds all the NIS+ principals in the doc.com. domain to the staff.doc.com. group. It is entered from a client in the doc.com. domain. Note the * symbol and the dot in front of the domain name.
client% nisgrpadm -a Staff *.doc.com. Added *.doc.com. to group Staff.manf.doc.com. |
This example adds the NIS+ group admin.doc.com. to the admin.manf.doc.com. group. It is entered from a client of the manf.doc.com. domain. Note the @ symbol in front of the group name.
client% nisgrpadm -a admin @admin.doc.com. Added @admin.doc.com. to group admin.manf.doc.com. |
To list the members of an NIS+ group, you must have read rights to the group object. Use the -l option:
This example lists the members of the admin.manf.doc.com. group. It is entered from a client in the manf.doc.com. group:
client% nisgrpadm -l admin Group entry for admin.manf.doc.com. group: No explicit members No implicit members: Recursive members: @admin.doc.com. No explicit nonmembers No implicit nonmembers No recursive nonmembers |
To remove members from an NIS+ group, you must have modify rights to the group object. Use the -r option:
nisgrpadm -r group-name members. . . |
This example removes the NIS+ principals allende and hugo.manf.doc.com. from the Ateam.sales.doc.com group. It is entered from a client in the sales.doc.com. domain:
client% nisgrpadm -r Ateam allende hugo.manf.doc.com. Removed allende.sales.doc.com. from group Ateam.sales.doc.com. Removed hugo.manf.doc.com. from group Ateam.sales.doc.com. |
This example removes the admin.doc.com. group from the admin.manf.doc.com. group. It is entered from a client in the manf.doc.com. domain:
client% nisgrpadm -r admin @admin.doc.com. Removed @admin.doc.com. from group admin.manf.doc.com. |
To find out whether an NIS+ principal is a member of a particular NIS+ group you must have read access to the group object. Use the -t option:
nisgrpadm -t group-name members. . . |
This example tests whether the NIS+ principal topadmin belongs to the admin.doc.com. group. It is entered from a client in the doc.com. domain.
client% nisgrpadm -t admin topadmin topadmin.doc.com. is a member of group admin.doc.com. |
This example tests whether the NIS+ principal jo, from the sales.doc.com. domain, belongs to the admin.sales.doc.com. group. It is entered from a client in the doc.com. domain.
client% nisgrpadm -t admin.sales.doc.com. jo.sales.doc.com. jo.sales.doc.com. is a member of group admin.sales.doc.com. |
