The rpc.nisd command starts the NIS+ daemon. The daemon can run in NIS-compatibility mode, which enables it to answer requests from NIS clients as well. You don't need any access rights to start the NIS+ daemon, but you should be aware of all its prerequisites and related tasks. They are described in Prerequisites to Running rpc.nisd.
By default, the NIS+ daemon starts with security level 2.
To start the daemon, use:
rpc.nisd |
To start the daemon in NIS-compatibility mode, use:
rpc.nisd -Y [-B] |
To start an NIS-compatible daemon with DNS forwarding capabilities, use:
rpc.nisd -Y -B |
Option |
Purpose |
-S security-level |
Specifies a security level, where 0 means no NIS+ security and 2 provides full NIS+ security. (Level 1 is not supported.) |
-F |
Forces a checkpoint of the directory served by the daemon. This has the side effect of emptying the directory's transaction log and freeing disk space. |
To start the NIS+ daemon on any server, use the command without options:
rpc.nisd |
The daemon starts with security level 2, which is the default.
To start the daemon with security level 0, use the -S flag:
rpc.nisd -S 0 |
You can start the NIS+ daemon in NIS-compatibility mode in any server, including the root master. Use the -Y (uppercase) option:
rpc.nisd -Y |
If the server is rebooted, the daemon will not restart in NIS-compatibility mode unless you also uncomment the line that contains EMULYP=Y in the server's /etc/init.d/rpc file.
You can add DNS forwarding capabilities to an NIS+ daemon running in NIS-compatibility mode by adding the -B option to rpc.nisd:
rpc.nisd -Y -B |
If the server is rebooted, the daemon will not restart in DNS-forwarding NIS-compatibility mode unless you also uncomment the line that contains EMULYP=-Y in the server's /etc/init.d/rpc file and change it to:
EMULYP -Y -B |
To stop the NIS+ daemon, whether it is running in normal or NIS-compatibility mode, kill it as you would any other daemon: first find its process ID, then kill it:
rootmaster# ps -e | grep rpc.nisd root 1081 1 61 16:43:33 ? 0:01 rpc.nisd -S 0 root 1087 1004 11 16:44:09 pts/1 0:00 grep rpc.nisd rootmaster# kill 1081 |
