The nisls command lists the contents of an NIS+ directory. To use it, you must have read rights to the directory object.
To display in terse format, use:
nisls [-dgLmMR] directory-name |
To display in verbose format, use:
nisls -l [-gm] [-dLMR] directory-name |
Option |
Purpose |
-d |
Directory object. Instead of listing a directory's contents, treat it like another object. |
-L |
Links. If the directory name is actually a link, the command follows the link and displays information about the linked directory. |
-M |
Master. Get the information from the master server only. Although this provides the most up-to-date information, it may take longer if the master server is busy. |
-R |
Recursive. List directories recursively. That is, if a directory contains other directories, their contents are displayed as well. |
-l |
Long. Display information in long format. Long format displays an object's type, creation time, owner, and access rights. |
-g |
Group. When displaying information in long format, display the directory's group owner instead of its owner. |
-m |
Modification time. When displaying information in long format, display the directory's modification time instead of its creation time. |
To list the contents of a directory in the default short format, use one or more of the options listed below and a directory name. If you don't supply a directory name, NIS+ will use the default directory.
nisls [-dLMR] directory-name |
or
nisls [-dLMR] |
For example, this instance of nisls is entered from the root master server of the root domain doc.com.:
rootmaster% nisls doc.com.: org_dir groups_dir |
Here is another example entered from the root master server:
rootmaster% nisls -R sales.doc.com. sales.doc.com.: org_dir groups_dir groups_dir.sales.doc.com.: admin org_dir.sales.doc.com.: auto_master auto_home bootparams cred . |
To list the contents of a directory in the verbose format, use the -l option and one or more of the options listed below. The -g and -m options modify the attributes that are displayed. If you don't supply a directory name, NIS+ will use the default directory.
or
nisls -l [-gm] [-dLMR] |
Here is an example, entered from the master server of the root domain doc.com.:
rootmaster% nisls -l doc.com. D r---rmcdr---r--- rootmaster.doc.com. date org_dir D r---rmcdr---r--- rootmaster.doc.com. date groups_dir |
