System Administration Guide: Naming and Directory Services (FNS and NIS+)
About Regular Expressions
Regular expressions are combinations of text and symbols that you can use to search for special configurations of column values. For example, the regular expression `Hello' searches for a value that begins with Hello. When using a regular expression in the command line, be sure to enclose it in quotes, since many of the regular expression symbols have special meaning to the Bourne and C shells. For example:
rootmaster% nisgrep -h greeting='Hello' phrases.doc.com.
The regular expression symbols are summarized in Table 19–7, below.
Table 19–7 Regular Expression Symbols
Symbol
Description
^string
Find a value that begins with string.
string $
Find a value that ends with string.
Find a value that has a number characters equal to the number of periods.
[chars]
Find a value that contains any of the characters in the brackets.
*expr
Find a value that has zero or more matches of the expr.
Find something that appears one or more times.
Find any value.
\'s-char'
Find a special character, such as ? or $.
x | y
Find a character that is either x or y.
