To remove a single entry from a table, use the -r option as described in Removing Single Table Entries.
To remove multiple entries from a table, use the -R option as described in Removing Multiple Entries From a Table
To remove a single entry from a table, use the -r option:
nistbladm -r indexed-name |
This example removes the Manf-1 entry from the depts table:
rootmaster% nistbladm -r [Dept=Manf-1,Site=Emeryville,Name=hosteen],\ depts.doc.com. |
You can specify as few column values as you wish. If NIS+ finds duplicates, it does not remove any entry and returns an error message instead. Thus, you could have removed the Manf-1 by specifying only the Site column value, as in this example:
rootmaster% nistbladm -r [Site=Emeryville],depts.doc.com. |
However, you could not have removed the Sales entry by specifying only the Site column value (SanFran), because two entries have that same value (R&D and Sales):
Dept |
Site |
Name |
R&D |
SanFran |
kuznetsov |
Sales |
SanFran |
jhill |
Manf-1 |
Emeryville |
hosteen |
Manf-2 |
Sausalito |
lincoln |
To remove multiple entries from a table, use the -R option:
nistbladm -R indexedname |
As with the -r option, you can specify as few column values as you wish. Unlike the -r option, however, if NIS+ finds duplicates, it removes all of them. You can find the name of a table's column by using the niscat -o command. This example removes all entries in which the Site is SanFran:
rootmaster% nistbladm -R [Site=SanFran],depts.doc.com. |
Dept |
Site |
Name |
Manf-1 |
Emeryville |
hosteen |
Manf-2 |
Sausalito |
lincoln |
You can use the -R option to remove all the entries from a table. Simply do not specify any column values between the square brackets, as in this example:
rootmaster% nistbladm -R [],depts.doc.com. |
When used with the nistbladm -R command, an empty set of square brackets is interpreted as a wildcard specifying all table rows.
