System Administration Guide: Naming and Directory Services (FNS and NIS+)
Creating Additional Automount Table
If you are creating an automount table, the table can have only two columns. The first column must be named key and the second column must be named value. For example, to create an automount table named auto1, you would enter:
master% nistbladm -c key-value key=S value= auto1.org_dir.doc.com.
