System Administration Guide: Naming and Directory Services (FNS and NIS+)
The nisln Command
The nisln command creates symbolic links between NIS+ objects such as tables and directories. All NIS+ administration commands accept the -L flag, which directs them to follow links between NIS+ objects.
Note –
Do not link table entries. Tables may be linked to other tables, but do not link an entry in one table to an entry in another table.
To create a link to another object (table or directory), you must have modify rights to the source object; that is, the one that will point to the other object or entry.
Caution – Caution –
Never link a cred table. Each org_dir directory should have its own cred table. Do not use a link to some other org_dir cred table.
Syntax
To create a link, use:
nisln source target
Table 19–9 nisln Options
Option
Description
-L
Follow links. If the source is itself a link, the new link will not be linked to it, but to that link's original source.
-D
Defaults. Specify a different set of defaults for the linked object. Defaults are described in Specifying Nondefault Security Values at Creation Time.
Creating a Link
To create a link between objects such as tables and directories, specify both object names: first the source, and then the target. Do not link table entries.
nisln source-object target-object
