System Administration Guide: Naming and Directory Services (FNS and NIS+)
Ensuring Compatibility With +/- Syntax
If +/- is used in /etc/passwd, /etc/shadow, and /etc/group files, you will need to modify the nsswitch.conffile to insure compatibility.
Note –
Users working on a client machine being served by an NIS+ server running in NIS compatibility mode cannot run ypcat on the netgroup table. Doing so will give you results as if the table were empty even if it has entries.
