The cred table stores credential information about NIS+ principals. Each domain has one cred table, which stores the credential information of client machines that belong to that domain and client users who are allowed to log into them. (In other words, the principals of that domain.) The cred tables are located in their domains' org_dir subdirectory.
Do not link a cred table. Each org_dir directory should have its own cred table. Do not use a link to some other org_dir cred table.
The cred table has five columns:
Table 23–4 cred Table
NIS+ Principal Name |
Authentication Type |
Authentication Name |
Public Data
Private Data
Principal name of a principal user |
LOCAL |
UID |
GID list |
Principal name of a principal user or machine |
DES |
Secure RPC netname |
Public key |
Encrypted private key |
The second column, authentication type, determines the types of values found in the other four columns.
LOCAL. If the authentication type is LOCAL, the other columns contain a principal user's name, UID, and GID; the last column is empty.
DES. If the authentication type is DES, the other columns contain a principal's name, Secure RPC netname, public key, and encrypted private key. These keys are used in conjunction with other information to encrypt and decrypt a DES credential.
See Chapter 12, Administering NIS+ Credentials for additional information on credentials and the cred table.
