The netmasks table contains the network masks used to implement standard Internet subnetting. The table has three columns:
Table 23–10 netmasks Table
Column |
Description |
Addr |
The IP number of the network |
Mask |
The network mask to use on the network |
Comment |
An optional comment about the entry |
For network numbers, you can use the conventional IP dot notation used by machine addresses, but leave zeros in place of the machine addresses. For example, this entry
128.32.0.0 255.255.255.0 |
means that class B network 128.32.0.0 should have 24 bits in its subnet field, and 8 bits in its host field.
