The auto_master table lists all the automounter maps in a domain. For direct maps, the auto_master table provides a map name. For indirect maps, it provides both a map name and the top directory of its mount point. The auto_master table has two columns:
Table 23–2 auto_master Table
Column |
Content |
Description |
Key |
Mount point |
The top directory into which the map will be mounted. If the map is a direct map, this is a dummy directory, represented with /—. |
Value |
Map name |
The name of the automounter map |
For example, assume these entries in the auto_master table:
/home auto_home /-auto_man /programs auto_programs |
The first entry names the auto_home map. It specifies the top directory of the mount point for all entries in the auto_home map: /home. (The auto_home map is an indirect map.) The second entry names the auto_man map. Because that map is a direct map, the entry provides only the map name. The auto_man map will itself provide the topmost directory, as well as the full path name, of the mount points for each of its entries. The third entry names the auto_programs map and, since it provides the top directory of the mount point, the auto_programs map is an indirect map.
All automounter maps are stored as NIS+ tables. By default, the Solaris environment provides the auto_master map, which is mandatory, and the auto_home map, which is a great convenience.
You can create more automounter maps for a domain, but be sure to store them as NIS+ tables and list them in the auto_master table. When creating additional automount maps to supplement auto_master (which is created for you), the column names must be key and value. For more information about the automounter consult your automounter or NFS file system documentation.
