The fnattr command can be used to add, delete or modify attributes associated with a name. You can make modifications one at a time, or batch several within the same command.
fnattr [-l] name to list attributes for name.
fnattr name -a-s -U -O attrib values to add an attribute
fnattr name -m -O -U attrib oldvalue newvalue to modify an attribute
fnattr name -d -O | -U [values attrib] to destroy an attribute
Option |
Description |
name |
The composite name. |
attrib |
The identifier of an attribute. |
values |
One or more attribute values. |
oldvalue |
An attribute value to be replaced by a new value. |
newvalue |
The attribute value that replaces an old value. |
-a |
Add an attribute. |
-d |
Destroy an attribute. |
-l |
List attributes. |
-m |
Modify an attribute. |
-s |
Replace all old attribute values with the new values for the attribute specified. |
-O |
The identifier format is FN_ID_ISO_OID_STRING, an ASN.1 dot-separated integer list string. |
-U |
The identifier format is FN_ID_DCE_UUID, a DCE UUID in string form. |
For example:
To show all of the attributes associated with the user name rosa:
# fnattr user/rosa |
To display the size attribute associated with the user uri:
# fnattr user/uri/ size |
For a user named devlin, to add an attribute named shoesize with a value of small, delete the hatsize attribute, and change the dresssize attribute value from 12 to 8:
# fnattr user/devlin -a shoesize small -d hatsize -m dresssize 12 8 |
