System Administration Guide: Naming and Directory Services (FNS and NIS+)
Determining Table Configurations
NIS+ tables provide several features not found in simple text files or maps. They have a column-entry structure, accept search paths, can be linked together, and can be configured in several different ways. You can also create your own custom NIS+ tables. When selecting the table configurations for your domains, consider the following factors discussed in the following sections:
Differences Between NIS+ Tables and NIS Maps
NIS+ tables differ from NIS maps in many ways, but two of those differences should be kept in mind during your namespace design:
NIS+ Standard Tables
Review the 17 standard NIS+ tables to make sure they suit the needs of your site. They are listed in NIS+ Standard Tables. Table 26–6 lists the correspondences between NIS maps and NIS+ tables.
Do not worry about synchronizing related tables. The NIS+ tables store essentially the same information as NIS maps, but they consolidate similar information into a single table (for example, the NIS+ hosts table stores the same information as the hosts.byaddr and hosts.byname NIS maps). Instead of the key-value pairs used in NIS maps, NIS+ tables use columns and rows. (See Table 26–6.) Key-value tables have two columns, with the first column being the key and the second column being the value. Therefore, when you update any information, such as host information, you need only update it in one place, such as the hosts table. You no longer have to worry about keeping that information consistent across related maps.
Note the new names of the automounter tables:
The dots were changed to underscores because NIS+ uses dots to separate directories. Dots in a table name can cause NIS+ to mistranslate names. For the same reason, machine names cannot contain any dots. You must change any machine name that contains a dot to something else. For example, a machine named sales.alpha is not allowed. You could change it to sales_alpha or salesalpha or any other name that does not contain a dot.
To make the transition from NIS to NIS+, you must change the dots in your NIS automounter maps to underscores. You may also need to do this on your clients' automounter configuration files. Refer to the following table:
Table 26–5 NIS+ Tables
NIS+ Table
Information in the Table
hosts
Network address and host name of every machine in the domain
bootparams
Location of the root, swap, and dump partition of every diskless client in the domain
passwd
Password information about every user in the domain
cred
Credentials for principals who belong to the domain
group
The group password, group ID, and members of every UNIX® group in the domain
netgroup
The netgroups to which machines and users in the domain may belong
mail_aliases
Information about the mail aliases of users in the domain
timezone
The time zone of the domain
networks
The networks in the domain and their canonical names
netmasks
The networks in the domain and their associated netmasks
ethers
The ethernet address of every machine in the domain
services
The names of IP services used in the domain and their port numbers
protocols
The list of IP protocols used in the domain
rpc
The RPC program numbers for RPC services available in the domain
auto_home
The location of all user's home directories in the domain
auto_master
Automounter map information
sendmailvars
Stores the mail domain
Table 26–6 Correspondences Between NIS Maps and NIS+ Tables
NIS Map
NIS+ Table
Notes
auto.home
auto_home
auto.master
auto_master
bootparams
bootparams
ethers.byaddr
ethers
ethers.byname
ethers
group.bygid
group
Not the same as NIS+ groups
group.byname
group
hosts.byaddr
hosts
hosts.byname
hosts
mail.aliases
mail_aliases
mail.byaddr
mail_aliases
netgroup
netgroup
netgroup.byhost
netgroup
netgroup.byuser
netgroup
netid.byname
cred
netmasks.byaddr
netmasks
networks.byaddr
networks
networks.byname
networks
passwd.byname
passwd
passwd.byuid
passwd
protocols.byname
protocols
protocols.bynumber
protocols
publickey.byname
cred
rpc.bynumber
rpc
services.byname
services
ypservers
Not needed
NIS+ has one new table for which there is no corresponding NIS table: sendmailvars. The sendmailvars table stores the mail domain used by sendmail.
NIS+ Tables Interoperate Differently With /etc Files
The manner in which NIS and other network information services interacted with /etc files in the SunOS 4.x environment was controlled by the /etc files using the +/- syntax. How NIS+, NIS, DNS and other network information services interact with /etc files in the Solaris operating environment is determined by the name service switch. The switch is a configuration file, /etc/nsswitch.conf, located on every Solaris operating environment client. It specifies the sources of information for that client: /etc files, DNS zone files (hosts only), NIS maps, or NIS+ tables. The nsswitch.conf configuration file of NIS+ clients resembles the simplified version in the following example.
Example 26–1 Simplified Name Service Switch File
passwd: files
group: compat
group_compat: nisplus
hosts: nisplus dns [NOTFOUND=return] files
services: nisplus [NOTFOUND=return] files
networks: nisplus [NOTFOUND=return] files
protocols: nisplus [NOTFOUND=return] files
rpc: nisplus [NOTFOUND=return] files
ethers: nisplus [NOTFOUND=return] files
netmasks: nisplus [NOTFOUND=return] files
bootparams: nisplus [NOTFOUND=return] files
publickey: nisplus
netgroup: nisplus
automount: files nisplus
aliases: files nisplus
In other words, for most types of information, the source is first an NIS+ table, then an /etc file. For the passwd and group entries, the sources can either be network files or from /etc files and NIS+ tables as indicated by +/- entries in the files.
You can select from three versions of the switch-configuration file or you can create your own. For instructions, see Chapter 1, The Name Service Switch.
Use of Custom NIS+ Tables
Determine which nonstandard NIS maps you use and their purpose. Can they be converted to NIS+ or replaced with NIS+ standard maps?
Some applications may rely on NIS maps. Will they still function the same way with NIS+, and can they function correctly in a mixed environment?
To build a custom table in NIS+, use nistbladm. Remember that you cannot use dots in the table names.
If you want to use NIS+ to support your custom NIS maps, you should create a key-value table, a table with two columns. The first column is the key and the second column is the value. If you then run the NIS+ servers in NIS-compatibility mode, the NIS clients will not notice any change in functionality.
Connections Between Tables
NIS+ tables contain information only about the resources and services in their home domain. If a client tries to find information that is stored in another domain, the client has to provide the other domain name. You can make this “forwarding” automatic by connecting the local table to the remote table. NIS+ tables can be connected in two different ways:
Do not use paths and links if you are going to have NIS clients in the NIS+ namespace, because NIS clients are unable to follow the paths or links to find the appropriate information.
Paths
If information in a particular NIS+ table is often requested by clients in other domains, consider establishing a path from the local NIS+ table to the one in the other domain. Refer to the following figure:
Figure 26–8 Establishing a Path to Tables in a Higher Domain
Diagram shows an established path to higher domains
Such a path has two main benefits. First, it saves clients in lower domains the trouble of explicitly searching through a second table. Second, it allows the administrator in the higher-level domain to make changes in one table and render that change visible to clients in other domains. However, such a path can also hurt performance. Performance is especially affected when searches are unsuccessful, because the NIS+ service must search through two tables instead of one. When you use paths, a table lookup now also depends upon the availability of other domains. This dependence can reduce the net availability of your domain. For these reasons, use paths only if you do not have any other solution to your problem.
You should also be aware that since “mailhost” is often used as an alias, when trying to find information about a specific mail host, you should use its fully qualified name in the search path (for example, mailhost.sales.com.); otherwise NIS+ will return all the “mailhosts” it finds in all the domains it searches through.
The path is established in the local table, with the -p option to the nistbladm command. To change a table's path, you must have modify access to the table object. To find a table's search path, use the niscat -o command (you must have read access to the table).
Links
Links between tables produce an effect similar to paths, except that the link involves a search through only one table: the remote table. With a search path, NIS+ first searches the local table, and only if it is unsuccessful does it search the remote table. With a link, the search moves directly to the remote table. In fact, the remote table virtually replaces the local table. The benefit of a link is that it allows a lower domain to access the information in a higher domain without the need to administer its own table.
To create a link, use the nisln command. You must have modify rights to the table object.
Deciding whether to use a path or to link NIS+ tables in a domain is a complex decision, but here are some basic principles:
Figure 26–9 Information Distribution Across an NIS+ Hierarchy
Diagram shows information distribution across a NIS+ hierarchy
