The tables in this section give a quick overview of the differences between NIS commands running in the Solaris 1 operating environment, NIS commands running in the Solaris 2 or Solaris 9 operating environment, and their NIS+ equivalents.
Table 26–10 describes which NIS commands are supported in the Solaris 2 and Solaris 9 releases.
Table 26–11 and Table 26–12 describe the NIS+ equivalents to NIS client and server commands in the Solaris 2 and Solaris 9 releases.
Table 26–13 contains a list of the NIS application programming interface functions and their NIS+ API equivalents, if they exist. See the appropriate man pages for details.
Only some NIS commands are supported in the Solaris 2 and Solaris 9 releases. NIS server commands are not shipped with the Solaris 2 and Solaris 9 releases. Only the NIS client commands are included. Whether these NIS commands run also depends on whether a Solaris 2 or Solaris 9 NIS client is making requests of an NIS server or of an NIS+ server in NIS-compatibility mode. NIS clients cannot make updates to NIS+ servers that are running in NIS-compatibility mode. For example, such clients cannot run the chkey and newkey commands. Table 26–10 lists the NIS commands supported in the Solaris 2 and Solaris 9 operating environments.
Table 26–10 NIS Commands Supported in the Solaris 2 and Solaris 9 Operating Environments|
Command Type |
NIS Commands Supported in the Solaris 2 and Solaris 9 Operating Environments |
NIS Commands Not Supported in the Solaris 2 and Solaris 9 Operating Environments |
Utilities |
ypinit ypxfr ypcat ypmatch yppasswd ypset ypwhich |
yppush yppoll ypchsh ypchfn ypmake |
Daemons |
ypbind |
ypserv ypxfrd rpc.ypupdated rpc.yppasswdd |
NIS API |
yp_get_default_domain() yp_bind() yp_unbind() yp_match() yp_first yp_next() yp_all() yp_master() yperr_string() ypprot_err() |
yp_order() yp_update() |
The two tables in this section contain NIS commands and their approximate NIS+ equivalents. The commands have been divided into two categories: Table 26–11 contains name service client commands and Table 26–12 contains name service server commands.
Table 26–11 shows client-to-name server commands. These commands are typed on name service client machines and request information of name service servers. The commands in column 1 run on Solaris 1, Solaris 2 or Solaris 9 NIS clients connected to Solaris 1 NIS servers. The commands in column 2 run on Solaris 1, Solaris 2, or Solaris 9 NIS clients connected to Solaris 2 or Solaris 9 NIS+ servers running in NIS-compatibility mode. The commands in column 3 only run on Solaris 2 or Solaris 9 NIS+ clients connected to Solaris 2 or Solaris 9 NIS+ servers. Commands are approximately equivalent across rows. “N/A” indicates that an equivalent command does not exist for that case.
Table 26–11 NIS Client Commands and Equivalent NIS+ Commands|
SunOS 4.x NIS Server |
NIS+ Server in NIS-Compatibility Mode |
NIS+ Server |
ypwhich -m |
ypwhich -m |
niscat -o org_dir |
ypcat |
ypcat |
niscat |
ypwhich |
ypwhich |
N/A |
ypmatch |
ypmatch |
nismatch/nisgrep |
yppasswd |
passwd |
passwd |
ypbind |
ypbind |
N/A |
yppoll |
N/A |
N/A |
ypset |
ypset |
N/A |
N/A |
ypinit -c |
nisclient -c |
Note that:
In the Solaris 2.5 release, the passwd command should be used regardless of NIS or NIS+ status. The functions previously performed by nispasswd and yppasswd have now been included in the passwd command.
The ypinit -c command is available only on Solaris 2 or Solaris 9 NIS clients.
The ypcat command is not supported for
queries directed to the netgroup table. The NIS client's request times out
before an answer is received because this table's format is so different
from the netgroup NIS map's format.
Table 26–12 shows name server-to-name server commands. The NIS server commands are not included in the Solaris 2 or Solaris 9 releases, so they are not available to either NIS+ servers or NIS+ servers in NIS-compatibility mode. In addition, an NIS server cannot make updates to an NIS+ server, nor can an NIS+ server make updates to an NIS server. Column 3 lists the NIS+ server commands that are equivalent to the NIS server commands in column 1. Servers in NIS-compatibility mode have no exact equivalents because NIS-compatibility mode refers only to client commands.
Table 26–12 NIS Server Commands and Equivalent NIS+ Commands|
NIS+ Server |
ypxfr |
N/A |
N/A |
makedbm |
N/A |
nisaddent |
ypinit -m ypinit -s |
N/A |
nisserver |
ypserv |
rpc.nisd -Y |
rpc.nisd |
ypserv -d |
rpc.nisd -Y -B |
No DNS forwarding needed; use /etc/nsswitch.conf |
ypxfrd |
N/A |
N/A |
rpc.ypupdated |
N/A |
N/A |
rpc.yppasswd |
rpc.nispasswdd |
rpc.nispasswdd |
yppush |
N/A |
nisping |
ypmake |
N/A |
nissetup, nisaddent |
ypxfr |
N/A |
N/A |
To completely convert your site to NIS+, you must both change the name service and port all applications to NIS+. Any internally created applications that make NIS calls have to be modified to use NIS+ calls. Otherwise, you always have to run your NIS+ servers in NIS-compatibility mode, with all the drawbacks that this mode entails. External applications may force you to run your namespace in NIS-compatibility mode until they are updated, as well.
Table 26–13 contains a list of the NIS API functions and their NIS+ API equivalents, if they exist.
Table 26–13 NIS API and NIS+ API Equivalent Functions|
NIS API Functions |
NIS+ API Functions |
yp_get_default_domain() |
nis_local_directory() |
ypbind() |
N/A |
ypunbind() |
N/A |
ypmatch() |
nis_list() |
yp_first() |
nis_first_entry() |
yp_next() |
nis_next_entry() |
yp_all() |
nis_list() |
yp_master() |
nis_lookup() |
yperr_string() |
nis_perror() nis_sperrno() |
ypprot_err() |
yp_order() |
N/A |
yp_update() |
nis_add_entry(), nis_remove_entry(), nis_modify_entry() |
