To check the input and returns of the sendmail rule sets, follow these instructions.
Change to address test mode.
# /usr/lib/sendmail -bt |
Test a mail address.
Provide the following numbers and address at the last prompt (>).
> 3,0 mail_address |
mail_address |
Use the mail address that you are testing. |
End the session.
Press Control-d.
The following is an example of the output.
% /usr/lib/sendmail -bt ADDRESS TEST MODE (ruleset 3 NOT automatically invoked) Enter <ruleset> <address> > 3,0 sandy@phoenix canonify input: sandy @ phoenix Canonify2 input: sandy < @ phoenix > Canonify2 returns: sandy < @ phoenix . example . com . > canonify returns: sandy < @ phoenix . example . com . > parse input: sandy < @ phoenix . example . com . > Parse0 input: sandy < @ phoenix . example . com . > Parse0 returns: sandy < @ phoenix . example . com . > ParseLocal input: sandy < @ phoenix . example . com . > ParseLocal returns: sandy < @ phoenix . example . com . > Parse1 input: sandy < @ phoenix . example . com . > MailerToTriple input: < mailhost . phoenix . example . com > sandy < @ phoenix . example . com . > MailerToTriple returns: $# relay $@ mailhost . phoenix . example . com $: sandy < @ phoenix . example . com . > Parse1 returns: $# relay $@ mailhost . phoenix . example . com $: sandy < @ phoenix . example . com . > parse returns: $# relay $@ mailhost . phoenix . example . com $: sandy < @ phoenix . example . com . > |
