To manage entries in an NIS+ table, you can use the aliasadm command. To list, add, modify, or delete table entries with the aliasadm command, you begin a particular task with the following steps.
Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
For information about roles, refer to "Using Privileged Applications" in System Administration Guide: Security Services.
Complete your task by following the instructions from the example that meets your requirements.
"Example-Listing the Entire Contents of the NIS+ mail_aliases Table"
"Example-Listing an Individual Entry From the NIS+ mail_aliases Table"
"Example-Listing Partial Matches From the NIS+ mail_aliases Table"
"Example-Adding Aliases to the NIS+ mail_aliases Table From the Command Line"
"Example-Adding Entries by Editing an NIS+ mail_aliases Table"
In some instances, you should begin the task by compiling a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
To create a table, follow these instructions.
Initiate an NIS+ table.
# aliasadm -I |
Add entries to the table.
To add two or three aliases, refer to "Example-Adding Aliases to the NIS+ mail_aliases Table From the Command Line".
To add more than two or three aliases, refer to "Example-Adding Entries by Editing an NIS+ mail_aliases Table".
For more information, refer to the aliasadm(1M) man page.
To see a complete list of the contents of the table, follow these instructions.
List all of the entries in alphabetical order by alias.
# aliasadm -1 |
To see an individual entry from the table, follow these instructions.
List an individual entry.
# aliasadm -m ignatz ignatz: ignatz@saturn # Alias for Iggy Ignatz |
The command matches only the complete alias name, not partial strings. You cannot use metacharacters (such as * and ?) with aliasadm -m.
To see partial matches from the table, follow these instructions.
List partial matches from the table.
# aliasadm -l | grep partial_string |
partial_string |
Use the string of your choice for your search. |
To add two or three aliases to the table, follow these instructions.
Compile a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
(Optional) If necessary, initiate an NIS+ table.
If you are creating a completely new NIS+ mail_aliases table, you must first initiate the table. To complete this task, refer to "Example-Initiating an NIS+ mail_aliases Table".
Add aliases to the table.
See this example of a typical entry.
# aliasadm -a iggy iggy.ignatz@saturn "Iggy Ignatz" |
The following list describes the input from the preceding example.
-a |
The option for adding an alias |
iggy |
The short form of the alias name |
iggy.ignatz@saturn |
The expanded alias name |
"Iggy Ignatz" |
The name for the alias in quotation marks |
Display the entry you created and ensure that it is correct.
# aliasadm -m alias |
alias |
The entry that you created |
To add more than two or three aliases to the table, follow these instructions.
Display and edit the aliases table.
# aliasadm -e |
This command displays the table and enables you to edit it. The editor you use has been set with the $EDITOR environment variable. If this variable is not set, vi is the default editor.
Use the following format to type each alias on a separate line.
alias: expanded_alias # ["option" # "comments"] |
alias |
This column is for the short form of the alias name. |
expanded_alias |
This column is for the expanded alias name. |
option |
This column is reserved for future use. |
comments |
This column is used for comments about the individual alias, such as a name for the alias. |
If you leave the option column blank, type an empty pair of quotation marks ("") and add the comments.
The order of the entries is not important to the NIS+ mail_aliases table. The aliasadm -l command sorts the list and displays the entries in alphabetical order.
For more information, refer to "Mail Alias Files" and the aliasadm(1M) man page.
To edit entries in the table, follow these instructions.
Display the alias entry.
alias |
Use the assigned alias name. |
Edit the alias entry, as necessary.
# aliasadm -c alias expanded_alias [options comments] |
alias |
If necessary, edit the alias name. |
expanded_alias |
If necessary, edit the expanded alias name. |
options |
If necessary, edit the option. |
comments |
If necessary, edit the comment for this entry. |
For more information, refer to the aliasadm(1M) man page, as well as "Mail Alias Files".
Display the entry that you have edited and ensure that the entry is correct.
To delete entries from the table, follow these instructions.
Delete an entry from the table.
# aliasadm -d alias |
alias |
Use the alias name for the entry that you are deleting. |
