A mail host resolves email addresses and reroutes mail within your domain. A good candidate for a mail host is a system that connects your network to the outside world or to a parent domain. The following procedure shows you how to set up a mail host.
Become superuser on the mail host system or assume an equivalent role.
For information about roles, refer to "Using Privileged Applications" in System Administration Guide: Security Services.
Stop sendmail.
# /etc/init.d/sendmail stop |
Verify the host-name configuration.
Run the check-hostname script to verify that sendmail can identify the fully qualified host name for this server.
% /usr/lib/mail/sh/check-hostname hostname phoenix OK: fully qualified as phoenix.example.com |
If this script is not successful in identifying the fully qualified host name, you need to add the fully qualified host name as the first alias for the host in /etc/hosts.
Update the /etc/hosts file.
Choose the step that is appropriate for you.
(Optional) If you are using NIS or NIS+, edit the /etc/hosts file on the system that is assigned to be the new mail host.
Add the word mailhost and mailhost.domain after the IP address and system name of the mail host system.
IP_address mailhost mailhost mailhost.domain loghost |
IP_address |
Use the assigned IP address. |
mailhost |
Use the system name of the mail host system. |
domain |
Use the expanded domain name. |
The system is now designated as a mail host. The domain should be identical to the string that is given as the subdomain name in the output of the following command.
% /usr/lib/sendmail -bt -d0 </dev/null
Version 8.12.0+Sun
Compiled with: LDAPMAP MAP_REGEX LOG MATCHGECOS MIME7TO8 MIME8TO7
NAMED_BIND NDBM NETINET NETINET6 NETUNIX NEWDB NIS NISPLUS
QUEUE SCANF SMTP USERDB XDEBUG
============ SYSTEM IDENTITY (after readcf) ============
(short domain name) $w = phoenix
(canonical domain name) $j = phoenix.example.com
(subdomain name) $m = example.com
(node name) $k = phoenix
See the following example of how the hosts file should look after these changes.
# cat /etc/hosts # # Internet host table # 172.31.255.255 localhost 192.168.255.255 phoenix mailhost mailhost.example.com loghost |
(Optional) If you are not using NIS or NIS+, edit the /etc/hosts file on each system in the network and create the following entry.
Select the correct configuration file to copy and rename.
The following command copies and renames the /etc/mail/main.cf file.
# cp /etc/mail/main.cf /etc/mail/sendmail.cf |
Restart sendmail.
# /etc/init.d/sendmail start |
Test your mail configuration.
See "How to Test the Mail Configuration" for instructions.
For further information about mail hosts, refer to "Hardware Components" in Chapter 26, Mail Services (Reference).
