Use the next task maps to quickly access PAP-related tasks for the dial-in server and trusted callers on dial-out machines.
Table 33-2 Task Map for PAP Authentication (Dial-in Server)|
Task |
Description |
For Instructions |
1. Gather preconfiguration information |
Collect data, such as user names, that is needed for authentication. | |
2. Update the password database, if necessary |
Ensure that all potential callers are in the server's password database. | |
3. Create the PAP database |
Create security credentials for all prospective callers in /etc/ppp/pap-secrets. | |
4. Modify the PPP configuration files |
Add options specific to PAP to the /etc/ppp/options and /etc/ppp/peers/peer-name files. |
"How to Add PAP Support to the PPP Configuration Files (Dial-in Server)" |
Table 33-3 Task Map for PAP Authentication (Dial-out Machine)
Task |
Description |
For Instructions |
Collect data, such as user names that is needed for authentication. | |
2. Create the PAP database for the trusted caller's machine |
Create the security credentials for the trusted caller and, if necessary, security credentials for other users who call the dial-out machine, in /etc/ppp/pap-secrets. |
"How to Configure PAP Authentication Credentials for the Trusted Callers" |
3. Modify the PPP configuration files |
"How to Add PAP Support to the PPP Configuration Files (Dial-out Machine)" |
