The procedure uses the PPP configuration files that were introduced in "How to Define Communications Over the Serial Line (Dial-in Server)" as examples.
Log in to the dial-in server as superuser.
Add authentication options to the /etc/ppp/options file.
For example, you would add the options in bold to an existing /etc/ppp/optionsfile to implement PAP authentication:
lock idle 120 nodefaultroute name myserver auth require-pap user myserver remotename user2 login |
Create an /etc/ppp/options.ttyname file, as described in "How to Define Communications Over the Serial Line".
Set up the $HOME/.ppprc file for each remote caller, as explained in "How to Configure Users of the Dial-in Server".
Task |
For Instructions |
Configure PAP authentication credentials for trusted callers of the dial-in server |
"Configuring PAP Authentication for Trusted Callers (Dial-out Machines)" |
