Solaris PPP 4.0 provides template files, each of which contains common options for a particular PPP configuration file. The next table lists the sample templates that can be used for setting up a dial-up link, and their equivalent Solaris PPP 4.0 files.
Template File |
PPP Configuration File |
For Instructions |
/etc/ppp/options.tmpl |
/etc/ppp/options | |
/etc/ppp/options.ttya.tmpl |
/etc/ppp/options.ttyname | |
/etc/ppp/myisp-chat.tmpl |
File with the name of your choice to contain the chat script | |
/etc/ppp/peers/myisp.tmpl |
/etc/ppp/peers/peer-name |
If you decide to use one of the template files, be sure to rename it to its equivalent PPP configuration file. The one exception is the chat file template /etc/ppp/myisp-chat.tmpl. You can give chat scripts any names that you want.
