Physically install the interface card into the local machine, if it is necessary.
Follow the instructions in the manufacturer's documentation.
Connect the cables from the CSU/DSU to the interface and, if it is necessary, from the CSU/DSU to the leased-line jack or similar connector.
Configure the CSU/DSU, as instructed in the documentation from the manufacturer or network provider.
The provider from whom you rented the leased line might supply and configure the CSU/DSU for your link.
Configure the interface card, if necessary, as instructed in the interface documentation.
The configuration of the interface card involves the creation of a startup script for the interface. The router at LocalCorp in the leased-line configuration that is shown in Figure 30-2 uses an HSI/S interface card.
The following script hsi-conf starts up the HSI/S interface:
#!/bin/ksh /opt/SUNWconn/bin/hsi_init hih1 speed=1536000 mode=fdx loopback=no \ nrzi=no txc=txc rxc=rxc txd=txd rxd=rxd signal=no 2>&1 > /dev/null |
hih1 |
Indicates that HSI/S is the synchronous port used |
speed=1536000 |
Sets the speed of the CSU/DSU to 1536000 |
Task |
For Instructions |
Configure the local machine on the leased line |
