Become superuser on the access server.
Add the name of the Ethernet interfaces that are dedicated to the PPPoE tunnels to the /etc/ppp/pppoe.if file.
For example, you would use the following /etc/ppp/pppoe.if file for the access server dslserve that is shown in "Example-Configuration for a PPPoE Tunnel".
# cat /etc/ppp/pppoe.if hme1 hme2 |
Configure the interfaces for PPPoE use.
# /etc/init.d/pppd start |
(Optional) Verify that interfaces on the server are now plumbed for PPPoE.
# /usr/sbin/sppptun query hme1:pppoe hme1:pppoed hme2:pppoe hme2:pppoed |
The previous sample shows that interfaces hme1 and hme2 are currently plumbed for PPPoE. You can also use the /usr/sbin/sppptun command to manually plumb interfaces for PPPoE. For instructions, refer to "/usr/sbin/sppptun Command".
