System Administration Guide: Resource Management and Network Services
How to Diagnose Modem Problems
The following steps help determine whether a faulty modem configuration causes link problems.
  1. Call the peer with debugging turned on, as explained in "How to Turn on PPP Debugging".
  2. Display the resulting /var/log/pppdebug log.
    Either of the following symptoms in the output can indicate a faulty modem configuration:
    • No "recvd" messages have come from the peer.
    • The output contains LCP messages from the peer, but the link fails with too many LCP Configure Requests messages sent by the local machine.
      These messages indicate that the local machine can hear the peer, but the peer cannot hear the local machine.
    • The link terminates with a SIGHUP signal.
  3. Use ping to send packets of various sizes over the link.
    For complete details about ping, refer to the ping(1M) man page.
    If small packets are received, but larger packets are dropped, modem problems are indicated.
  4. Check for errors on interface sppp0:
    % netstat -ni
    Name  Mtu  Net/Dest   Address      Ipkts    Ierrs Opkts    Oerrs Collis Queue
    lo0   8232 127.0.0.0  127.0.0.1    826808   0     826808   0     0      0
    hme0  1500 172.21.0.0 172.21.3.228 13800032 0     1648464  0     0      0
    sppp0 1500 10.0.0.2   10.0.0.1     210      0     128      0     0      0
    If interface errors increase over time, this can indicate problems with the modem configuration.
