System Administration Guide: Resource Management and Network Services
Configuring Communications Over the Dial-in Server
The next task shows how to enable the dial-in server to open communications with any dial-out machine, based on options that are defined in the following PPP configuration files:
For detailed information about these files, refer to "Using PPP Options in Files and on the Command Line".
Before you proceed, you should have done the following:
