Before you perform the next procedure, you must have completed the following:
Set up and configured the synchronous devices for the link, as described in "Configuring Synchronous Devices on the Leased Line"
Obtained the root password for the local machine on the leased line
Set up the local machine to run as a router on the network(s) to use the services of the leased-line provider
