Use the next chat script as a template for calling an ISP from a dial-out machine with a US Robotics Courier modem.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" AT&F1M0&M5S2=255 SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c \r \d\c SAY "Connected; running PPP\n" |
The following table describes the contents of the chat script.
Script Contents |
Explanation |
ABORT BUSY |
Abort transmission if the modem receives this message from the opposite peer. |
ABORT 'NO CARRIER' |
REPORT CONNECT |
Gather the CONNECT string from the modem and print it out. |
TIMEOUT 10 |
Set initial timeout to 10 seconds. The modem's response should be immediate. |
"" AT&F1M0M0M0M0&M5S2=255 |
M0 - Turn off the speaker during connect. &M5 - Make the modem require error control. S2=255 - Disable the TIES "+++" break sequence. |
SAY "Calling myisp\n" |
Display the message "Calling myisp" on the local machine. |
TIMEOUT 60 |
Reset the timeout to 60 seconds to allow more time for link negotiation. |
OK "ATDT1-123-555-1212" |
Call the remote peer by using the phone number 123-555-1212. |
CONNECT \c |
Wait for the CONNECT message from the opposite peer's modem. |
\r \d\c |
Wait until the end of the CONNECT message. |
Display the informative message "Connected; running PPP" on the local machine. |
