SAY "Calling the peer"
Display this message on the screen of the dial-out machine.
TIMEOUT 10
Set the initial timeout to 10 seconds.
ABORT BUSY
Abort transmission if the modem receives this message from the
opposite peer.
ABORT 'NO CARRIER'
opposite peer.
ABORT ERROR
opposite peer.
REPORT CONNECT
Gather the CONNECT string from
the modem and print it out.
AT&FB40S83.7=
1&K44&J3X7S61.3=1
S0=0S2=255
The letters in this line have
the following meaning:
&F - Use factory default
B40 - Do asynchronous PPP conversion
S83.7=1 - Use data over speech bearer
&K44 - Enable CCP compression
&J3 - Enable MP
X7 - Report DCE side rates
S61.3=1 - Use packet fragmentation
S0=0 - No auto answer
S2=255 - Disable TIES escape
OK ATDI18882638234
Make an ISDN call. For multi-link, the second call is placed
to the same telephone number, which is normally what is required by most ISPs.
If the remote peer requires a different second phone number, append "+nnnn" (nnnn represents the
second phone number).
CONNECT \c
Wait
for the CONNECT message from the opposite
peer's modem.
\r \d\c
Wait until the end of
the CONNECT message.
SAY "Connected; running
PPP\n"
Display
