System Administration Guide: Resource Management and Network Services
Using the login Option With /etc/ppp/pap-secrets
You can add the login option for authenticating PAP credentials to any PPP configuration file. When login is specified, for example, in /etc/ppp/options, pppd verifies that the caller's PAP credentials exist in the Solaris password database. The following table shows the format of a /etc/ppp/pap-secrets file with the login option.
Table 36-6 /etc/ppp/pap-secrets With login Option
Caller
Server
Password
IP Addresses
joe
sally
sue
The parameters have the following meanings:
Caller
Names of all authorized callers.
Server
Asterisk, which indicates that any server name is valid. The name option is not required in the PPP configuration files.
Password
Double quotes, which indicate that any password is valid.
If you type a password in this column, then the password that is supplied by the peer must match both the PAP password and the UNIX passwd database.
IP Addresses
Asterisk, which indicates that any IP address is allowed.
