You can configure the characteristics of communications on the serial line in the /etc/ppp/options.ttyname file. /etc/ppp/options.ttyname is a privileged file that is read by pppd after parsing the /etc/ppp/options and $HOME/.ppprc files, if they exist. Otherwise, pppd reads /etc/ppp/options.ttyname after parsing /etc/ppp/options.
ttyname is used for both dial-up and leased-line links. ttyname represents a particular serial port on a machine, such as cua/a or cua/b, where a modem or ISDN TA might be attached.
When naming the /etc/ppp/options.ttyname file, replace the slash (/) in the device name with a dot (.) . For example, the options file for device cua/b should be named /etc/ppp/options.cua.b.
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. If the server only has one serial line for PPP and requires few options, you can specify these options in another configuration file or on the command line.
For a dial-up link, you might choose to create individual /etc/ppp/options.ttyname files for every serial port on a dial-in server with a modem attached. Typical options include the following:
IP address required by the dial-in server
Set this option if you require incoming callers on serial port ttyname to use a particular IP address. Your address space might have a limited number of IP addresses available for PPP in comparison to the number of potential callers. If this is the situation, consider assigning an IP address to each serial interface that is used for PPP on the dial-in server. This assignment implements dynamic addressing for PPP.
asyncmap map_value
The asyncmap option maps control characters that cannot be received over the serial line by the particular modem or ISDN TA. When the xonxoff option is used, pppd automatically sets an asyncmap of 0xa0000.
map_value states, in hexadecimal format, the control characters that are problematic.
init "chat -U -f /etc/ppp/mychat"
The init option tells the modem to initialize communications over the serial line by using the information in the chat -U command. The modem uses the chat string in the file /etc/ppp/mychat.
Security parameters that are listed in the pppd(1m) man page
For a dial-out machine, you can create an /etc/ppp/options.ttyname file for the serial port with the modem, or elect not to use /etc/ppp/options.ttyname.
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. If the dial-out machine only has one serial line for PPP and requires few options, you can specify these options in another configuration file or on the command line.
The /etc/ppp/options.ttya.tmpl file contains helpful comments about the /etc/ppp/options.tty-name file. The template contains three common options for the /etc/ppp/options.tty-name file.
38400 asyncmap 0xa0000 :192.168.1.1 |
Option |
Definition |
38400 |
Use this baud rate for port ttya. |
asyncmap 0xa0000 |
Assign the asyncmap value of 0xa0000 so that the local machine can communicate with broken peers. |
:192.168.1.1 |
Assign the IP address 192.168.1.1 to all peers that are calling in over the link. |
To use /etc/ppp/options.ttya.tmpl at your site, rename /etc/ppp/options.tmpl to /etc/ppp/options.ttya-name. Replace ttya-name with the name of the serial port with the modem. Then modify the file contents as needed by your site.
Example /etc/ppp/options.ttyname |
For Instructions |
For a dial-out machine | |
For a dial-in server |
"How to Define Communications Over the Serial Line (Dial-in Server)" |
