System Administration Guide: Resource Management and Network Services
How to Log In to a Remote System (rlogin)
Log in to a remote system by using the rlogin(1) command.
$ rlogin [-l user-name] system-name
rlogin
(No options) Logs you in to the remote system directly, effectively, with your current user name
-l user-name
Logs you into the remote system indirectly;, effectively, with the user name you supply
If the network attempts to authenticate you, you are not prompted for a password. If the remote system attempts to authenticate you, you are asked to provide a password.
If the operation succeeds, the rlogin command displays brief information about your latest remote login to that system, the version of the operating system that is running on the remote system, and whether you have mail waiting for you in your home directory.
Example-Logging In to a Remote System (rlogin)
The following example shows the output of a direct remote login to pluto. The user has been authenticated by the network.
$ rlogin starbug
Last login: Mon Jul 12 09:28:39 from venus
Sun Microsystems Inc.   SunOS 5.8       February 2000
starbug:
The following example shows the output of an indirect remote login to pluto, with the user being authenticated by the remote system.
$ rlogin -l smith pluto
password: user-password
Last login: Mon Jul 12 11:51:58 from venus
starbug:
