Use this procedure if you are not using Volume Manager.
Become superuser or assume an equivalent role.
For information about roles, see "Using Privileged Applications" in System Administration Guide: Security Services.
Update the autofs map.
Add an entry for the CD-ROM file system, which should resemble the following:
hsfs -fstype=hsfs,ro :/dev/sr0 |
The CD-ROM device you intend to mount must appear as a name that follows the colon.
