Become superuser or assume an equivalent role.
For information about roles, see "Using Privileged Applications" in System Administration Guide: Security Services.
Run the cfsadmin command to create a cache directory on the local disk.
# cfsadmin -c /var/cache |
Add the cachefs entry to the appropriate automounter map.
For example, adding this entry to the master map caches all home directories:
/home auto_home -fstype=cachefs,cachedir=/var/cache,backfstype=nfs |
Adding this entry to the auto_home map only caches the home directory for the user who is named rich:
rich -fstype=cachefs,cachedir=/var/cache,backfstype=nfs dragon:/export/home1/rich |
Options that are included in maps that are searched later override options set in maps that are searched earlier. The last options that are found are the ones that are used. In the previous example, a specific entry added to the auto_home map only needs to include the options listed in the master maps if some of the options needed to be changed.
