Become superuser or assume an equivalent role.
For information about roles, see "Using Privileged Applications" in System Administration Guide: Security Services.
Create the following entry in the name service auto_master file, either NIS or NIS+:
/home auto_home -nosuid |
The nosuid option prevents users from creating files with the setuid or setgid bit set.
This entry overrides the entry for /home in a generic local /etc/auto_master file (see the previous example). The override happens because the +auto_master reference to the external name service map occurs before the /home entry in the file. If the entries in the auto_home map include mount options, the nosuid option is overwritten. Therefore, either no options should be used in the auto_home map or the nosuid option must be included with each entry.
Do not mount the home directory disk partitions on or under /home on the server.
