Assign your domain a domain name, and make the domain name known to each computer in the domain.
See the System Administration Guide: Naming and Directory Services (FNS and NIS+) if you are using NIS+ as your name service.
Establish public keys and secret keys for your clients' users by using the newkey or nisaddcred command. Have each user establish his or her own secure RPC password by using the chkey command.
For information about these commands, see the newkey(1M), the nisaddcred(1M), and the chkey(1) man pages.
When public keys and secret keys have been generated, the public keys
and encrypted secret keys are stored in the publickey
database.
Verify that the name service is responding. If you are running NIS+, type the following:
# nisping -u Last updates for directory eng.acme.com. : Master server is eng-master.acme.com. Last update occurred at Mon Jun 5 11:16:10 1995 Replica server is eng1-replica-replica-58.acme.com. Last Update seen was Mon Jun 5 11:16:10 1995 |
If you are running NIS, verify that the ypbind daemon is running.
Verify that the keyserv daemon (the key server) is running.
Type the following command.
# ps -ef | grep keyserv root 100 1 16 Apr 11 ? 0:00 /usr/sbin/keyserv root 2215 2211 5 09:57:28 pts/0 0:00 grep keyserv |
If the daemon isn't running, start the key server by typing the following:
# /usr/sbin/keyserv |
Decrypt and store the secret key.
Usually, the login password is identical to the network password. In this situation, keylogin is not required. If the passwords are different, the users have to log in, and then do a keylogin. You still need to use the keylogin -r command as root to store the decrypted secret key in /etc/.rootkey.
You need to run keylogin -r if the root secret key changes or /etc/.rootkey is lost.
Update mount options for the file system.
Edit the /etc/dfs/dfstab file and add the sec=dh option to the appropriate entries (for Diffie-Hellman authentication).
share -F nfs -o sec=dh /export/home |
See the dfstab(4) man page for a description of /etc/dfs/dfstab.
Update the automounter maps for the file system.
Edit the auto_master
data
to include sec=dh as a mount option in the
appropriate entries (for Diffie-Hellman authentication):
/home auto_home -nosuid,sec=dh |
Releases through Solaris 2.5 have a limitation. If a client does not mount as secure a file system that is shared as secure, users have access as user nobody, rather than as themselves. With version 2 on later releases, the NFS server refuses access if the security modes do not match, unless -sec=none is included on the share command line. With version 3, the mode is inherited from the NFS server, so clients do not need to specify sec=dh. The users have access to the files as themselves.
When you reinstall, move, or upgrade a computer, remember to save /etc/.rootkey if you do not establish new keys or change them for root. If you do delete /etc/.rootkey, you can always type the following:
# keylogin -r |
