Use this command to mount all file systems or a specific group of file systems that are listed in a file-system table. The command provides a way to do the following:
Select the file-system type to be accessed with the -F FSType option
Select all the remote file systems that are listed in a file-system table with the -r option
Select all the local file systems with the -l option
These two examples are equivalent:
# mountall -F nfs |
# mountall -F nfs -r |
