Some of the options that you can include with the -o flag are as follows.
The pathname file system is shared read-write or read-only for all clients.
The file system is shared read-write for the clients that are listed only. All other requests are denied. Starting with the Solaris 2.6 release, the list of clients that are defined in accesslist has been expanded. See "Setting Access Lists With the share Command" for more information. You can use this option to override an -ro option.
