System Administration Guide: Resource Management and Network Services
Using the rpcinfo Command
This example gathers information on the RPC services that are running on a server. The text that is generated by the command is filtered by the sort command to make it more readable. Several lines that list RPC services have been deleted from the example.
% rpcinfo -s bee |sort -n
   program version(s) netid(s)                         service     owner
    100000  2,3,4     udp6,tcp6,udp,tcp,ticlts,ticotsord,ticots rpcbind     superuser
    100001  4,3,2     ticlts,udp,udp6                  rstatd      superuser
    100002  3,2       ticots,ticotsord,tcp,tcp6,ticlts,udp,udp6 rusersd     superuser
    100003  3,2       tcp,udp,tcp6,udp6                nfs         superuser
    100005  3,2,1     ticots,ticotsord,tcp,tcp6,ticlts,udp,udp6 mountd      superuser
    100007  1,2,3     ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 ypbind      superuser
    100008  1         ticlts,udp,udp6                  walld       superuser
    100011  1         ticlts,udp,udp6                  rquotad     superuser
    100012  1         ticlts,udp,udp6                  sprayd      superuser
    100021  4,3,2,1   tcp,udp,tcp6,udp6                nlockmgr    superuser
    100024  1         ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 status      superuser
    100029  3,2,1     ticots,ticotsord,ticlts          keyserv     superuser
    100068  5         tcp,udp                          cmsd        superuser
    100083  1         tcp,tcp6                         ttdbserverd superuser
    100099  3         ticotsord                        autofs      superuser
    100133  1         ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 -           superuser
    100134  1         ticotsord                        tokenring   superuser
    100155  1         ticots,ticotsord,tcp,tcp6        smserverd   superuser
    100221  1         tcp,tcp6                         -           superuser
    100227  3,2       tcp,udp,tcp6,udp6                nfs_acl     superuser
    100229  1         tcp,tcp6                         metad       superuser
    100230  1         tcp,tcp6                         metamhd     superuser
    100231  1         ticots,ticotsord,ticlts          -           superuser
    100232  10        udp,udp6                         sadmind     superuser
    100234  1         ticotsord                        gssd        superuser
    100235  1         tcp,tcp6                         -           superuser
    100242  1         tcp,tcp6                         metamedd    superuser
    100249  1         ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 -           superuser
    300326  4         tcp,tcp6                         -           superuser
    300598  1         ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 -           superuser
    390113  1         tcp                              -           unknown
 805306368  1         ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 -           superuser
1289637086  1,5       tcp                              -           26069
This example shows how to gather information about a particular RPC service by selecting a particular transport on a server.
% rpcinfo -t bee mountd
program 100005 version 1 ready and waiting
program 100005 version 2 ready and waiting
program 100005 version 3 ready and waiting
% rpcinfo -u bee nfs
program 100003 version 2 ready and waiting
program 100003 version 3 ready and waiting
The first example checks the mountd service that is running over TCP. The second example checks the NFS service that is running over UDP.
