A direct map is an automount point. With a direct map, a direct association exists between a mount point on the client and a directory on the server. Direct maps have a full path name and indicate the relationship explicitly. This is a typical /etc/auto_direct map:
/usr/local -ro \
/bin ivy:/export/local/sun4 \
/share ivy:/export/local/share \
/src ivy:/export/local/src
/usr/man -ro oak:/usr/man \
rose:/usr/man \
willow:/usr/man
/usr/games -ro peach:/usr/games
/usr/spool/news -ro pine:/usr/spool/news \
willow:/var/spool/news
Lines in direct maps have the following syntax:
key [ mount-options ] location
key |
key is the path name of the mount point in a direct map. |
mount-options |
mount-options is the options you want to apply to this particular mount. These options are required only if they differ from the map default. Options for each specific type of file system are listed in the mount man page for that file system. For example, see the mount_cachefs(1M) man page for CacheFS specific mount options. |
location |
location is the location of the file system, specified (one or more) as server:pathname for NFS file systems or :devicename for High Sierra file systems (HSFS). Note - The pathname should not include an automounted mount point. The pathname should be the actual absolute path to the file system. For instance, the location of a home directory should be listed as server:/export/home/username, not as server:/home/username. |
As in the master map, a line that begins with # is a comment. All the text that follows until the end of the line is ignored. Put a backslash at the end of the line to split long lines into shorter ones.
Of all the maps, the entries in a direct map most closely resemble the corresponding entries in /etc/vfstab. An entry might appear in /etc/vfstab as follows:
dancer:/usr/local - /usr/local/tmp nfs - yes ro |
The equivalent entry appears in a direct map as follows:
/usr/local/tmp -ro dancer:/usr/local |
No concatenation of options occurs between the automounter maps. Any options that are added to an automounter map override all options that are listed in maps that are searched earlier. For instance, options that are included in the auto_master map would be overridden by corresponding entries in any other map.
See "How Autofs Selects the Nearest Read-Only Files for Clients (Multiple Locations)" for other important features that are associated with this type of map.
In Example 16-1, the mount point /- tells autofs not to associate the entries in auto_direct with any specific mount point. Indirect maps use mount points that are defined in the auto_master file. Direct maps use mount points that are specified in the named map. Remember, in a direct map the key, or mount point, is a full path name.
An NIS or NIS+ auto_master file can have only one direct map entry because the mount point must be a unique value in the name space. An auto_master file that is a local file can have any number of direct map entries, if entries are not duplicated.
