System Administration Guide: Resource Management and Network Services
Autofs and Weighting
You can influence the selection of servers at the same proximity level by adding a weighting value to the autofs map. For example:
/usr/man -ro oak,rose(1),willow(2):/usr/man
The numbers in parentheses indicate a weighting. Servers without a weighting have a value of zero (most likely to be selected). The higher the weighting value, the lower the chance the server is selected.
Note -
All other server selection factors are more important than weighting. Weighting is only considered when selecting between servers with the same network proximity.
